Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
Teenet
Jan 16, 2017Guide
Hi again,
Apologies for my late reply...
Eventually I didn't contact support as I found a power supply with the same specs as the one provided at home. At the moment I'm using it and it's ok Welch means the original power supply was indeed faulty.
Thanks again for your assistance!
JohnRo
Jan 16, 2017NETGEAR Employee Retired
Hi Teenet,
That's great! You can still contact support for the replacement of the original power supply so that you'll have a spare.
Have a great day!
Thanks,
