cdrose
Aug 07, 2024Aspirant
NETGEAR MS305 & Virgin Media Hub 5 - No internet (2.5GbE)
Hi everyone, Recently received my MS305 switch. Plugged it into my current working setup and now getting no internet. - VM Hub5 2.5GbE output to MS305 port 5 (Cat7) - MS305 port 4 to my PC (Cat...
Aug 07, 2024Guru - Experienced User
Try port 1 from the MS305 to the ISP modem?
Power off the gateway modem off for 30 seconds then back ON?
cdrose
Aug 08, 2024Aspirant
This didn't work unfortunately.
I read a post on the Virgin Media forums that they had an issue with their 2.5 port on their router and disabled "802.03az (Energy Efficient Ethernet)" on their switch.
Assuming I can't do this as it's unmanaged.
I've plugged the switch into a 1GbE port on the router now and it works fine. So clearly it seems there's an issue with my router port.
