jvarney7601
Jul 31, 2026Follower
Netgear Switch G5316v3
I setup a new home network and it worked for 3 mins then it stopped. Nighthawk MS80 system Modem connected to Mesh Router which is connected to Netgear G5316V3 16 port unmanaged switch which i th...
schumaku
Aug 02, 2026Guru - Experienced User
A GS316v3 - 16-port Gigabit Ethernet Unmanaged Essentials Switch isn't it? As you mentioned unmanaged switch, it was moved to the apporopriate commmunity section.
Have only one of the MR80 (thats the router) connected to one LAN port [C] on the switch?
jvarney7601 wrote:The Switch lights are all blinking and power is on. When i power cycle the switch the internet does not come back, however all the ports are blinking like its sending data.
Left and right port LEDs blinking indicate that all ports are operating on Gigbit, at a 1 Gbps link rate.
What happens when you connect say one PC direct to one of the MR80 (or a MS80) LAN port?
Have already cold rebooted the MR80 (the router) by disconnecting (wait some 10 seconds just in case) and reconnecting the power?
Does the PC get an IP address assigned from the router DHCP server, not nagging something like "no Internet"?
