hshah96's avatar
hshah96
Network Switches
Hi   Is it possible to get an unmanaged network switch, at least some 1Gb port and PoE.   Please let me know   Thanks
  • DaneA's avatar
    Jul 31, 2016
    Hi hshah96,
    As far as I know, the NETGEAR unmanaged Gigabit PoE switch like the GS108P is already End-of-Life (EOL).  I suggest you to check the GS110TP which is an 8-port Gigabit PoE Smart Managed Switch with 2 Gigabit Fiber SFP.  You may also use the GS110TP just like an unmanaged switch.  Click on the links below to know more about GS110TP:
    GS110TP Product FAQs
    GS110TP Data Sheet
    DaneA
    NETGEAR Community Team
ProSupport for Business
