bwca-guy's avatar
bwca-guy
New GS308 does not work consistently
I am struggling to get my new GS308 switch working. I move the cable from my Apple Extreme over to tehe GS308 (into the far left port), and then move the remaing cables. Some devices work, some don't. All lights are green and blinking. I move the cables back to the Apple Extreme, and everything works again. What am I doing wrong, or could it be a defective product? I've reviewed youtube videos for installation tips, and it looks pretty straight forward.
Help!
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    bwca-guy
    Welcome to the community!
    Given that the GS308 is an unmanaged switch, connecting it to your AirPort Extreme should work as intended (having more Ethernet ports for your network), where one of the 3 ports of the AirPort Extreme connects to any port of the GS308.
    First thing you can try is to check if the Ethernet cables being used are working; if possible, try swapping them and see if it makes a difference.
    Also, what devices work and don't work when the switch is involved?
    JeraldM
    NETGEAR Community Team
    • bwca-guy's avatar
      bwca-guy
      Thanks for the ideas...I was thinking there might be some problem with my old cables and will be replacing them (although they work on the Apple device). Will also try switchin existing cables on curretn devices.
      WHat does't work on the new switch:
      1) direct connection to Dell PC
      2) HVAC WI-fi device
      I'll get new cables and see how that works
      Thanks!
      Bryan
    • bwca-guy's avatar
      bwca-guy
      I am now getting a good wi-fi signal, but my ethernet connection didn't improve with a new cable. I went into Microsoft help, and followed teh instructions to reset my network settings. After rebooting the PC...it worked! Now I just have to get teh HVAC wifi working, and I'm back in business. I think this fix will require the HVAC company to make a visit to my home.
      Thx,
      Bryan
ProSupport for Business
