LTDJeremy's avatar
LTDJeremy
No Power To POE on GS305P
HI All, I have a GS305P, which I'm trying to use to run some PTZ cameras.  The cameras should have the correct POE protocol (IEEE 802.3af standard). https://www.amazon.com/gp/product/B076KQC5M2/ref...
  • DaneA's avatar
    Nov 19, 2020
    LTDJeremy,
    Welcome to the community! :)
    The GS305P only supports IEEE 802.3af standard which is PoE (Power over Ethernet) on 4 LAN ports.  As reference, kindly check page 3 of its data sheet here.
    Searched online and found out that the LEFTEK Dome Camera 2.5'' Mini POE Dome PTZ Camera that it support IEEE802.3at standard which is PoE+.  As reference, kindly check the manual I found here.
    I suggest you to replace the GS305P with a GS305PP.  The GS305PP supports both PoE & PoE+ on 4 LAN ports.  Kindly check page 3 of the data sheet here.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
