pdjhh
Jan 05, 2023Tutor
Not enough power?
Hi there. I have one install with about 10 of these poe+ switches with cambium poe+ access points on most ports and all is good. I have another site with one of these switches and just 2 of th...
Jan 05, 2023Guru - Experienced User
There's different power adapters for those models that allow different power levels. If you look at what power adapter is on the switch, it should tell you what power it puts out on the datasheet for that supply. That could be the difference.
What Cambium AP is it? It could be boarder line "just enough" power for short distances but with longer runs, have enough power loss it isn't stable.
