pdjhh
Jan 05, 2023Tutor
Not enough power?
Hi there. I have one install with about 10 of these poe+ switches with cambium poe+ access points on most ports and all is good. I have another site with one of these switches and just 2 of th...
pdjhh
Jan 05, 2023Tutor
Yeh I always use the same, big power supplies so it's not that.
Jan 05, 2023Guru - Experienced User
What cambium ap is it?
- pdjhhJan 05, 2023Tutor
Cambium e425h. As I say I've got about 60 of these runing on the same switches at another venue with no hiccups at all.
- schumakuJan 06, 2023Guru - Experienced User
pdjhh wrote:
Cambium e425h.
Reads like a standard 802.3af or 802.3at powered device. Sufficient power to operate single 802.3af units (non-cascaded), permitting there is enough power available from the GS116PP.
- plemansJan 06, 2023Guru - Experienced User
Yeah they should have enough power.
did you test them with a short cable run connected to that power supply?
Maybe there's an issue with the cabling l
