MusicianTech99
Dec 17, 2022Aspirant
Ok So to Extend an Ethernet Connection... hmmm mmm
For S%$tz and Giggles Ok so I liked about three feet to lay an ethernet connection. Found an old net gear fs105 5 port unmanned ehternet switch box. Is this going to be more trouble then getting ...
schumaku
Dec 18, 2022Guru - Experienced User
If the 10/100Mb/s link is sufficient, yes. That's the beauty of Ethernet.
- MusicianTech99Dec 18, 2022Aspirant
Yeah I saw that one. Im guessing contemporary switches have gotten alot faster to handle the 1G of data per second i do believe that the newer tech is now able to deliver and perform.
- schumakuDec 18, 2022Guru - Experienced User
well, it depends what link rate you expect, and what kind of services are run.
On basic audio (not talking of ICMP multicast and the like), for some web administration, for non high-performance file transfers, and much more Fast Ethernet can be perfectly sufficient.
