randomuser987
Jun 14, 2022Aspirant
Only two devices connect to internet via switch on modem-only
Hi, I can only connect two ethernet devices (laptop and desktop computer) to the internet. Even though there are 5 ports on the switch, only two devices can connect to the internet concurrently. T...
Marc_V
Jun 14, 2022NETGEAR Employee Retired
Those IPs are provided by your ISP if you are not using a router. ISP usually provide a single WAN IP for the router but if you have a block of IP then it will be assigned to the devices connecting to the modem, in this case 2 devices can connect then 2 IPs are provided. Have you checked with your ISP regarding the block of WAN IP you have?
IMO, it would be best to have a router in place.
randomuser987
Thank you! I will check with the ISP.
