Jupitermoon25
Dec 17, 2016Aspirant
POE IP Security Camera Switch
I have an unopened Netgear Prosafe GS108 Gigabit Switch. Can I use this switch for my long distance POE IP security cameras? 5 cameras are 130 feet away and I need a switch to connect them to the ...
- Dec 25, 2016
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Dec 18, 2016NETGEAR Employee Retired
Hi Jupitermoon25,
Welcome to the community! :)
The GS108 switch does not support PoE. I recommend you the GS110TP switch which supports PoE on all 8 ports and you can use this with your 5 cameras. Be sure to you use CAT5e or CAT6 ethernet cables between the GS110TP switch and the 5 cameras.
To know more about the GS110TP, kindly access the data sheet here.
DaneA
