qseal
Apr 25, 2022Aspirant
POE+ with Cisco AP
As I just know that GS510TPP supports POE+ from your website, but I am not sure if it can support cisco 3820 ap. Could you please advise if the netgear poe switch support 2-4 cisco 3820 ap?
- qsealAspirantAs I just know that GS510TPP supports POE+ from your website, but I am not sure if it can support cisco 3802 ap. Could you please advise if the netgear poe switch support 2-4 cisco 3802 ap?
- JohnC_VNETGEAR Employee Retired
Hi qseal,
Welcome to our community! 🙂
As long as the AP supports IEEE 802.3at/af then it should work just fine with the GS510TPP. Unless the AP does support passive POE and not active.
John
NETGEAR Community Team
