ShanePrince
Apr 04, 2017Aspirant
Port Aggregation Setup on R8500 Nighthawk X8 and S808e Nighthawk switch
Hi All I am only finding articles around this topic for the R9000 Nighthawk Router and Nighthawk Switch. Has anyone configured Port Aggregation between R8500 Nighthawk X8 Router and S808e Nighthawk...
- Apr 13, 2017
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Apr 10, 2017NETGEAR Employee Retired
I am afraid to inform you that the Nighthawk GS808e Gaming switch only supports static LAG while the Nighthawk R8500 router only supports LACP (or dynamic LAG). For you to double check, kindly read page 48 of the GS808e user manual here and read page 66 of the R8500 user manual here.
DaneA
DaneA
Apr 13, 2017NETGEAR Employee Retired
DaneA
