MBIMGCTRL
Jan 08, 2018Aspirant
Power supply voltage range
Throughout the documentation, available on NETGEARs website, the power supply voltage range is not specified - only the output voltage of the enclosed wall socket power adapter (12V). So does anyone...
MBIMGCTRL
Jan 09, 2018Aspirant
Sorry, my question was not formulated correctly!
What I meant was - what is the power supply voltage range for the GS105? The inlet is marked 12 VDC but the allowed input v-range is not specified anywere.
BR MB
schumaku
Jan 09, 2018Guru - Experienced User
+/-5% should be fine.
- GregLockJan 18, 2018Aspirant
Would it be safe to say that the GS105 can operate with 16.8v? This is to confirm if a solar power pack can support the GS105 power requirements.
Appologies, I meant 14.8VDC above.
- rodneywaterratJun 22, 2022Aspirant
I can't speak for Netgear but they probably don't support using anything other than the supply that it ships with.
However, it will probably work. I have had the FS105 running on the 12Volt system on my boat for a year now, and some times the voltage has gone has high as 15.5V and below 12.0V it has worked with no apparent problems.
Personally, I would just try it. I have have GS305 in the post, and if it breaks as a result of me powering this way then I've lost £18 - I've been doing this sort of thing for years and never had a problem yet so £18 is a small risk in that context.
If you considering doing this with more expensive equipment I would consider looking into a installing a regulated 12V feed for example something based on the LM2577 regulator which can handle the input voltage going either lower or higher than the target voltage.
