Mavrina
Sep 29, 2017Aspirant
Prosafe GS108 v3 is not discovered by the utility
My network is as follows R1 a router modem Netgear D6200 connected to adsl SW1 switch GS608v3 attached to R1 SW2 switch GS108v3 attached to SW1 SW3 switch GS605v3 attached to SW1 The pr...
- Sep 29, 2017
Hi Mavrina,
Welcome to our community!
The GS108 doesn't have any firmware as this is just a plug and play device. GS108E model is the one with the firmware and not the GS108v series. Even if you use a prosafe utility, definitely it will not be detected as you cannot do anything on the switch anymore. You can just reset it by rebooting the switch.
Please check the datasheet here.
Mavrina
Sep 30, 2017Aspirant
Thanks.
Just one clarification
The re is no reset button. ..... in the place where rhere shuld be. (According to the picture.) There is a written AUTO UPLINK
