engineer2021
May 02, 2021Aspirant
Rack mount kit for GS116LP
Hello, I purchased my switch second-hand and it did not arrive with the brackets used to rack-mount it. I cannot figure out how to find matching brackets. The rack is the standard 19” width. ...
engineer2021
Thank you! I tried to find some way to contact their customer service and didn’t have any luck.
I’ll shoot them an email and post back in case anyone runs across this in the future.
DaneA
May 03, 2021NETGEAR Employee Retired
Welcome to the community! :)
Here is the part code for the rackmount kit for GS116LP switch: 422-10112-01
Use the part code to inquire for the rackmount kit for GS116LP switch on stores or online stores that might have it.
DaneA
NETGEAR Community Team
- engineer2021May 03, 2021AspirantDaneA
Thanks a lot for the part number! A quick search using eBay, Amazon, and quoting the part number in Google doesn’t appear to bring up any results.
I did email the support team so maybe I’ll hear back from them this week.
In the interim, would you have any other suggestions on how to track down that part?
Thanks again! And I appreciate the warm welcome.- DaneAMay 03, 2021NETGEAR Employee Retired
Good to know that you have already sent an e-mail to the NETGEAR Support Team. I suggest to kindly wait for their response.
DaneA
