usao
Dec 23, 2016Aspirant
2x gs116 wont link
I have 2x GS116 switches. The first is my primary switch, out of the router. The second is in my server room, and port 1 is connected with a straight-through cable to the second. It will not link ...
usao
Dec 25, 2016Aspirant
The 2 switches are connected to eachother via a 75ft cable going through the ceiling.
Additionally, I have an 8-port Netgear switch in the server room currently, and it has no trouble connecting using the same wire.
My intention was to expand the available ports to 16 from 8, but can't get it to work.
I then took the second GS116 next to my main GS116 at the router location.
What I see is interesting.
The main Netgear GS116 switfch has both port lights on for the short cable going to the second GS116. However, the second GS116 still shows no other lights other than the power light. No port lights.
When I plug in a Raspberry pi to the second GS116, I get lights on the port for the pi, but the uplink port remains dark, and I have no network connection through that switch.
usao
Some other notes:
1) I know the cable is good as it works currently between the old GS116 and the 8port switch.
2) The new GS116 doesn't work, even when moved next to the old GS116 and directly connected.
3) Regardless of which port on the new switch I try to use for the uplink, it doesn't connect, no port lights and no connectivity.
4) I have not tried switching both the GS116 as that would involve an outage which would be difficult to manage (nfs mounts and iscsi traffic between multiple nodes and a qnap array). Ill see if I can do that in the next few days to see if the new switch can uplink to the router.
- usaoDec 26, 2016Aspirant
Here is a pix of my testing setup.
The working GS116 is in back, the new GS116 is up front.
I have a straight through cable connected from the old GS116 to the new GS116 in port 1.
As you can see, no lights on the new GS116, although the old GS116 shows both port lights on.
Computers plugged into the new GS116 can talk to each other, but cannot see anything through the uplink. The internet is not visable and the default router is not seen either.
Thus, my conclusing that the switches cannot uplink.
Looking for suggestions as I need to use this GS116 in the server room as I am out of physical ports on my 8port netgear currently in the server room.
- DaneADec 27, 2016NETGEAR Employee Retired
usao,
Kindly try to use a crossover cable between the 2 GS116 switches. Let us know the results.
DaneA
NETGEAR Community Team
- usaoDec 28, 2016Aspirant
Ive ordered a crossover adapter from ebay, will take a week to get here.
However, reading GS116 docs indicate it supports auto uplink.
Auto Uplink™ automatically adjusts for straight-through or crossover cables
