usao
Dec 24, 2016Aspirant
2x gs116 wont link
I have 2x GS116 switches. The first is my primary switch, out of the router. The second is in my server room, and port 1 is connected with a straight-through cable to the second. It will not link ...
DaneA
Jan 04, 2017NETGEAR Employee Retired
usao
Jan 04, 2017Aspirant
Well, further testing showed that the problem is with the ports on the left side of the switch.
I was not able to get any lights from hosts or the uplink on the left side, but the ports on the right side did work.
I contacted the seller on ebay and he agreed to a return.
So, I believe the switch is defective.
