Darthswan
Oct 27, 2022Follower
Replacement power adapter for GS116LP
I’m looking for a replacement power adapter for my poe switch. GS116LP. I. can’t seem to find any in stock. It is the 200 W model. Thank you in advance for your help. K
schumaku
Oct 28, 2022Guru - Experienced User
The GS116LP was provided originally with a EPS90W 90W External Power Supply, 54V @ 1.66A, 110-240V, 50/60Hz
According to the GS108LP, GS108PP, GS116LP, GS116PP Data Sheet the GS116LP does become a GA116PP if equipped with a 200W EPS200W.
The power supply version does depend on the power required for the PoE devices.
