Darthswan
Oct 27, 2022Follower
Replacement power adapter for GS116LP
I’m looking for a replacement power adapter for my poe switch. GS116LP. I. can’t seem to find any in stock. It is the 200 W model. Thank you in advance for your help. K
user45874
Mar 28, 2026Aspirant
Old post but try this 54V 3.7A 200W power supply - exact same specs as the discontinued Netgear one:
Meanwell OWA-200E-54
Retails for around £50
https://uk.farnell.com/mean-well/owa-200e-54/power-supply-ac-dc-1o-p-3-71a/dp/3764276
https://www.mouser.co.uk/ProductDetail/MEAN-WELL/OWA-200E-54?qs=iLbezkQI%252BsjpA%252BZSsGVfyg%3D%3D
https://www.digikey.co.uk/en/products/detail/mean-well-usa-inc/OWA-200E-54/14307069
Has an EU plug but just use an adaptor or swap for a UK one
