johnrdonovan1
May 18, 2016Aspirant
Setting up NETGEAR ProSAFE JGS524 w/ Wireless Access Points
Wanted to get some advise from the community regarding my Netgear JGS524 Unmanaged Switch. I am about to set up a home network with the following devises: Netgear CM600 Router Netgear ProSA...
- May 19, 2016
Hi johnrdonovan1,
Kinda missed that, sorry! Yes, it is only a modem so you'll basically need a modem-router combo (gateway - to replace the CM600) or a router. So the setup will be CM600>Router>Switch. The CM600 will not be able to accommodate the IP addressing.
Thanks,
JohnRo
May 18, 2016NETGEAR Employee Retired
Hello johnrdonovan1,
Welcome to the community!
This should work fine considering the location of the devices and since the switch is only unmanaged. It would be better though if you will connect some of the devices (probably the ones near the router) to the CM600 router. All in all this setup is great. :)
Let us know if you have more questions.
Thanks,
- johnrdonovan1May 18, 2016Aspirant
Thanks JohnRo - I was looking at this again and was wondering if I needed to change on of the ASUS Routers from an access point and place it in between the CM600 and the switch. I was reading more on the CM600 and it looks like it is just a modem. Any thoughts?
- JohnRoMay 19, 2016NETGEAR Employee Retired
Hi johnrdonovan1,
Thanks,
- JohnRoMay 23, 2016NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
