johnrdonovan1's avatar
May 18, 2016
Setting up NETGEAR ProSAFE JGS524 w/ Wireless Access Points
Wanted to get some advise from the community regarding my Netgear JGS524 Unmanaged Switch.  I am about to set up a home network with the following devises:   Netgear CM600 Router Netgear ProSA...
  • JohnRo's avatar
    JohnRo
    May 19, 2016
    Hi johnrdonovan1,
    Kinda missed that, sorry! Yes, it is only a modem so you'll basically need a modem-router combo (gateway - to replace the CM600) or a router. So the setup will be CM600>Router>Switch. The CM600 will not be able to accommodate the IP addressing.
    Thanks,
ProSupport for Business
