ElitePCgamer
Jun 16, 2016Aspirant
Switch added, limited connection on 1 device
I have recently added a ProSafe GS108 switch to my home network. My wired pc's are able to access the internet but my media streaming Android box has very limited connection meaning I can do a speed test from the media box, access some streaming content but I can't access Netflix or any apps like gmail, playstore, etc. Any ideas?
It was user error on my side
- JohnRoNETGEAR Employee Retired
Hello ElitePCgamer,
Welcome to the community!
The GS108 is only a passthrough switch and does not have any QoS settings so I don't think it has anything to do with the limited connection on the Android Box. Did you test if you get the same behavior if the Android Box is connected directly to the router?
Thanks,
- ElitePCgamerAspirant
Hello ElitePCgamer,
Thank you for the clarification. If this post had helped you in any way, please mark it as "Accept as Solution".
Have a great day!
Thanks,
Hi ElitePCgamer,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
