sanslos
Jul 01, 2019Aspirant
Unable to register GS324 ("Unable to register product to your account: Product not found.")
I have a new GS324 unmanaged switch, purchased a couple of weeks ago. When I try to register it, there is a popup error message that says:
I verified the serial number on the box and the product, they are the same.
Kindly send me the serial number of the GS324 switch via private message and I'll inquire it to the NETGEAR Support Team.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
I got an update from the NETGEAR Support Team that the serial number of your GS324 switch has been registered already under your name.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
DaneA
- sanslosAspirant
The serial number needed to be added by the support team. It didn't follow the current, expected, numbers, apparently it is a new series of numbers. All is fixed now.
