a2736
Mar 12, 2017Aspirant
UNMANAGED SWITCHES
NEED TO REPLACE MY UNMANAGED FS108 SWITCH AS MY INTERNET SPEED HAS INCREASED TO 300 MBPS . NEED AN 8 PORT WHAT IS THE BEST CHOICE FOR REPLACEMENT (MODEL NUMBER) ?
a2736
Mar 13, 2017Aspirant
DANE
THANK YOU VERY MUCH FOR YOUR ADVISE . I WILL BUY GS108 AN INTALL IT. AS FAR AS THE ROUTER CONCERNED . MY ROUTER IS AN AIRPORT EXTREME AND DOES SUPPORT SPEEDS UP TO 1GB. ALSO STRANGELY ENOUGH WITH MY FS108 SWITCH I AM GETTING 300 SPEED ON ONE PORT AND LESS THAN 100 (40 TO 50 MBPS) IN THE OTHER 6 PORTS.
a2736
DANE
ONE MORE QUESTION ON AMAZON THEY ADVERTISE THE GS108 SWITCH AS GS108 WITHOUT THE 8v4 affix . I AM ASSUMING IS THE SAME SWITCH. PLEASE CORRECT ME IF I AM WRONG
