nusya
Aug 26, 2019Aspirant
What is the differences between GS308v2 and GS308v3?
Hello, we have quoted prices from our local supplier to purchase GS308-v3 for several units. But when delivery, we received GS308-v2 instead. Is there any major differences between both, as NETGear ...
- Aug 26, 2019
Welcome to the community! :)
Here below are the differences between the GS308v2 and GS308v3:
As reference, kindly check the respective data sheets below:
If your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Aug 26, 2019NETGEAR Employee Retired
DaneA
nusya
Hi DaneA,
thank you for the explanation,
Now I confidences enough to push our local supplier for getting the correct item :)
Regards
nusya
