karldschubert
Oct 02, 2017Aspirant
Which Power Supply is the one for the GS108v2 & GS108v3
Greetings! I have two switches, a GS108v2 & a GS108v3 and two power supplies with different specs. I've looked at the online documentation and on the back of the switches and see that the power supp...
- Oct 02, 2017There's no need to be concerned. You can safely use a 1.5 A power supply on a device that only needs 1 A. The device will only use as much current as it needs.
On the flip side, it would be dangerous to use a power supply with a lower amperage rating than what the device needs.
And in all cases, the voltage of the power supply MUST match what the device needs.
karldschubert
Thank you very much!
JohnC_V
Oct 03, 2017NETGEAR Employee Retired
Welcome to our community!
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- karldschubertOct 03, 2017Aspirant
