engravosaurus
Dec 15, 2015Aspirant
why does FS105 have / need an IP address
newbie query
have a FS105 and it has an IP address
why does this switch need an IP address?
thank you
- Dec 17, 2015
thanks
am on Mac OS El Capitan
tried ipconfig but I guess the Mac version does not include /all
router is leased from Whidbey Tel and they do permit end users to log in to the router
but
riddle is solved
I crawled up into the ceiling, unstrapped the ADT Pulse Gateway, turned it over, and what did I find
in teeny tiny letters "by Netgear of California" with a MAC address that matches
so
when Fing, etc report IP and MAC by Netgear, they are correct
they are referring to the ADT Pulse device, NOT the Netgear switch
so riddle is solved, thank you all
engravosaurus
thank you
netgear has 3 cables
1 input from a linksys switch
2 output to jack in the storage room which is empty
3 empty
4 empty
5 to ADT alarm systemwifi
DaneA
Dec 16, 2015NETGEAR Employee Retired
Hi engravosaurus,
Is the Linksys switch a manageable switch? If yes, then possibly the IP address you see belongs to the Linksys switch.
DaneA
NETGEAR Community Team
