klaus11
Apr 16, 2021Tutor
WNDR3700 with GS116 Problems
Hi! I have the following network: Netgear GS116 16port gigabit switch. on this switch my Router ModelNetgear WNDR3700 v2/WNDR37AV v2/WNDR3800/WNDR38AV Firmware VersionDD-WRT v3.0-r40559 std (0...
klaus11
Apr 17, 2021Tutor
ok guys. right now I have the solution!!
If your switch is not able to cope with 1Gbit, all devices which have 1 Gbit and connected to the switch doesn't work.
In my case, the wifi router behind the switch couldn't connect.
So the solution was to open the GS116 switch. I just looked for the capacitors.
There are 2 different capacitors:
4 pices of 470uF 16V and
2 pieces of 820uF 6,4V
I changed one of the 820uF to a 820uF 16V. and now the swich can cope with 1Gbit again!
Very nice !!
bye Klaus
