ChuckInKC
May 24, 2024Tutor
XS508M slow speed
My network is composed of a Google multigig router and a single Netgear XS508M switch. PCs have 10G network adaptors. I have 8G service with Google. If I run the Ethernet cable from the Google ...
May 24, 2024Guru - Experienced User
Try with some CAT6A STP cabling?
ChuckInKC
May 24, 2024Tutor
Thanks for the reply. Since my last post, I had some new cable delivered. CAT 8 SSTP. Same symptoms.
- homelab_guyJun 14, 2024Aspirant
Did you ever figure this out? I am having the exact same issue with this switch.
