jkeats's avatar
jkeats
Novice
Mar 19, 2015
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea...
I've got the WNDR4300 with the latest firmware. I use an Arris cable modem (I have that set to bridged so it won't double up on the NAT). My internet speed is 200mbps and I get that on my desktop PC which is wire into the router. On WiFi, though, even when I'm right in front of the router, I can't get any speeds faster than a max of 35mbps, which seems really low. I've tested with an iphone 5, a laptop and a Kindle Fire HD and they all get about that speed (using the Ookla speed test).
I have tried the following:
      Nothing has caused the wifi to be any faster than 20-35mbps.
      Any other ideas out there as to what to try? Is there a setting I'm missing? Again, the internet speed coming through the router to my desktop is 200mbps it's just the WiFi that's much slower. I know I can't expect to get a full 200 but 20-30 seems pretty low, especially when I'm testing right in front of the router.
    Any help would be greatly appreciated!
  • Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
