ChuckInKC
May 24, 2024Tutor
XS508M slow speed
My network is composed of a Google multigig router and a single Netgear XS508M switch. PCs have 10G network adaptors. I have 8G service with Google. If I run the Ethernet cable from the Google ...
homelab_guy
Jun 14, 2024Aspirant
ChuckInKC Did you ever figure this out? I have the exact same Router, ISP and switch and I'm getting terrible perofrmance with the switch. If I connect directly to my 10Gb router I get full speed.
- ChuckInKCJun 14, 2024Tutor
I didn't. I bought another router which is working perfectly.
- homelab_guyJun 14, 2024Aspirant
Many thanks for the reply. I'm trying to escalate with Netgear support. Will update if I ever get resolution.
- BrianLJun 16, 2024NETGEAR Moderator
Hi homelab_guy,
Welcome to the Community!
What did support tell you? If the unit is up to date and the same issue persists, a replacement can be issued.
Kind regards,
BrianL
