ChuckInKC
May 24, 2024Tutor
XS508M slow speed
My network is composed of a Google multigig router and a single Netgear XS508M switch. PCs have 10G network adaptors. I have 8G service with Google. If I run the Ethernet cable from the Google ...
ChuckInKC
Jun 14, 2024Tutor
I didn't. I bought another router which is working perfectly.
homelab_guy
Jun 14, 2024Aspirant
Many thanks for the reply. I'm trying to escalate with Netgear support. Will update if I ever get resolution.
- BrianLJun 16, 2024NETGEAR Moderator
Hi homelab_guy,
Welcome to the Community!
What did support tell you? If the unit is up to date and the same issue persists, a replacement can be issued.
Kind regards,
BrianL
- homelab_guyJun 20, 2024Aspirant
Netgear sent me an RMA unit and it had the same behavior. The computer would get full speed when connected directly to the Google Fiber Router. However, If I connect the computer to the switch which then uplinked to the router I would get terrible speeds. The switch would report 10Gb based on the LEDs.
I asked Google to replace my Google Fiber Router (GFRG300) with a newer model (GR6EXX0C) and that instantly solved the issue. I am able to utilize my full speed when connected to the switch now.
I suspect there is a strange bug between either the switch or old router model that caused the issue, but I'm guessing it's rather cryptic. I'm just glad it works now.
- BrianLJun 24, 2024NETGEAR Moderator
Hi homelab_guy,
Likely, the LAN port speed settings are not set to auto or at least full-duplex. Anyway, I am glad that using another router (updated one) fixed the issue.
Kind regards
BrianL,
