X99's avatar
X99
Best choice for a router
Hi everyone. I work for a small company. Our building has 3 floors, and an optic-fiber has been set up on second floor. The router onto which the fiber is connected is no manageable by us, all we ha...
  • DaneA's avatar
    Jul 22, 2019
    X99,
    Welcome to the community ! :)
    If you are really sure that the GE4 port of the existing router gives a Public WAN IP Address and you want to connect your own firewall router to it, I suggest you the BR500 firewall router.  The BR500 has 1 WAN port and 4 LAN ports.  For more information, kindly access its data sheet below:
    BR500 Data Sheet
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
