stringbean's avatar
stringbean
Initiate
Oct 01, 2021
BR200 automatic Failover for ISP
I'm having a lot of downtime recently from my primary ISP. I have the BR200 as the first connection to my network from my cable modem. I would like to add a second connection from a different ISP with an automatic failover so when an outage occurs in my primart ISP, i can retain some functionality. How would I do this with the BR200 Insight VPN Router? If its not possible, what are my options?
Thanks!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    stringbean,
    Welcome to the community! :)
    What you want to implement is not possible since the BR200 only has one (1) WAN port.  You may want to post your concern on the Idea Exchange for Business board here.  In this way, the development team can see what feature does BR200 users wanted to be added to the functionality of the product. Be reminded that the more kudos given by community members to your feature request will help as the development team will be reviewing the post that has the most kudos and might get considered to be implemented.
    DaneA
    NETGEAR Community Team
    • ZbigT's avatar
      ZbigT
      Guide
      DaneA wrote:
      [..] You may want to post your concern on the Idea Exchange for Business board here.  In this way, the development team can see what feature does BR200 users wanted to be added to the functionality of the product. Be reminded that the more kudos given by community members to your feature request will help as the development team will be reviewing the post that has the most kudos and might get considered to be implemented. [..]
      And I would say: don't bother. I've been told by none other than a Netgear support team member that BR200 is an End-Of-Life product and any fixes it might receive will be security fixes only. I suggest you cut your losses and invest your time and money in a brand that doesn't EOL its "business" gear less than a year after announcing it.
      BTW, if MrJoshW stumbles upon this, I'd be happy to get any update on that RMA I've been promised.
      • stringbean's avatar
        stringbean
        Initiate
        Man that's frustrating. You're right DaneA . How in the world is this an "EOL" product already!?
        When I was deciding on what ecosystem to invest in for my restaurant locations i had so many assurances that Netgear was "committed to the insight platform and hardware". Unfortunately that doesn't seem to be the case at all. I have have thousands invested in insight hardware between 6 locations and somehow they all seem to be "End-of-life" products. I should have gone with my gut and thrown my lot in with cisco. I guess i backed the wrong horse.
  • I believe this discussion was up with the BR500 as well.
    The discussion was around ability to parallel connect to two devices with one WAN each and allowing them to act as main and backup through LAN.
ProSupport for Business
