Shaggysan
Apr 11, 2024Aspirant
BR200 Factory reset after poweroutage.
I have a site with a BR200, FirmwareV5.10.0.5, that has factory reset itself after a power outage. The first time there was a several day outage at the site and when it came back up I noticed the net...
- Aug 11, 2026
And then there is Step "iv"
iv/ The BR200 restarts and that loses all the config again.
This is an old thread, but there is no work around for this.
If you save the config to a file or have it on an Insight server, the results will be the same. The reason is that the BR200 will restart / reboot after it uploads the previously saved config file. After that, it comes back up with a Factory Default config.
If someone would post a picture of the PCB that highlights the NAND chip and includes the part number, we could fix it ourselves instead of throwing it away.
