amabirts's avatar
amabirts
BR200 IPv6 on LAN
The topic was raised a while ago, but the only solution provided was to read pages 30-31 of manual. However, having read them before checking here they don’t provide a solution.
The BR200 gets an IPv6 WAN but not on LAN, behind a Netgear Nighthawk router. VPN traffic isn’t IPv6. Is there something I’m doing wrong?
Thanks in advance.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    amabirts,
    Welcome to our community! :)
    The BR200 can be fed by an IPv6 on WAN but it can also provide IPv6 on LAN. Is this what you are trying to achieve?
    John
    NETGEAR Community Team
    • amabirts's avatar
      amabirts
      Hi John,
      Thanks, that’s exactly it. It shows it has an IPv6 address on WAN, but LAN shows as Not Available. A test for IPv6 of connected devices through VPN connection shows they fail. Either I’m setting it up incorrectly or there’s another issue (changing to DHCP does not resolve issue).
      Kind regards,
      Steven
      • schumaku's avatar
        schumaku
        What is the IPv6 prefix assigned on the BR200 WAN port? If your ISP only assigns a /64 prefix, you can't further subnet. If there is e.g. a /60 prefix, you should be able to create four /64 prefix subnets.
ProSupport for Business
