Artmarks
Jan 10, 2021Aspirant
BR200 not "currently" working with existing OSX Server VPN
Hello America, I hope you are all well. After 9 years of using an Apple Airport Extreme as a router in addition to 3 other Extremes being used as access points, we decided to upgrade our router t...
- Jan 11, 2021
Hello,
The port forwarding rules appear to be correc as the traffic would hit the IP ending in .225.
IPSEC is it's own VPN however the BR200 only does site to site IPSEC and you cannot use it as a client to site solution. What resources are being accessed on the Mac server that is needing to be accessed remotely? Do you know if you are able to access the resouces locally?
