it-ledmax
Sep 28, 2022Aspirant
BR200 with WAX610 connectivity problems
Hello, I have a BR200 with some WAX610 APs that create a large wifi network. After about 8 months of everything working fine I am dealing with a major problem : Any device that I connect on...
JeraldM
Sep 30, 2022NETGEAR Employee Retired
Welcome to the community!
Were there any events or any configurations performed that might have caused the issue?
Are they connecting to the Guest WiFi or just the Wireless 1 network?
Is the network being managed via NETGEAR Insight or just locally?
Lastly, kindly check if the devices are updated to the latest FW (BR200 FW v5.10.0.5 and WAX610 FW v10.2.0.16).
JeraldM
NETGEAR Community Team
- it-ledmaxOct 02, 2022Aspirant
Hello,
Everything is updated to the latest firmware.
Network is managed via Insight.I turned off the Access Control List but nothing changed.
Must be a setting in the BR200 router that I am missing.
Any ideea is welcomed.
Thank you.- JeraldMOct 04, 2022NETGEAR Employee Retired
Hi it-ledmax,
Given that it's managed via Insight, have you tried creating a new SSID and connecting to it to see if it's the same issue?
You may check this video for your reference.
JeraldM
- it-ledmaxOct 06, 2022Aspirant
Hi,
Same issue with new SSID.
I'm thinking the BR200 router is causing this issue.
Thanks for your suggestion.
