Daikan
May 08, 2019Initiate
BR500 connectivity to CenturyLink ISP
It appears that the BR500 (5.6.0.1 or previous versions) is not able to connect the internet when using a CenturyLink ISP fiber modem such as calix 716GE-I. The problem is that CenturyLink requires a...
MrJoshW
May 20, 2019NETGEAR Employee Retired
Hello,
IPTV bridging found in the local interface of the BR500 will allow you to tag a VLAN on the WAN port provided by your internet provider. Page 91 of the user manual will walk you through on how to set up the VLAN bridging in the local interface. Let me know if this helps.
http://www.downloads.netgear.com/files/GDC/BR500/BR500_UM_EN.pdf
- Jan 04, 2019Retired_Member
