Daikan
May 08, 2019Initiate
BR500 connectivity to CenturyLink ISP
It appears that the BR500 (5.6.0.1 or previous versions) is not able to connect the internet when using a CenturyLink ISP fiber modem such as calix 716GE-I. The problem is that CenturyLink requires a...
JohnC_V
May 20, 2019NETGEAR Employee Retired
Hi MrJoshW,
Honest mistake :) I overlooked that on the manual.
JohnCarloV
NETGEAR Community Team
- DaikanMay 20, 2019Initiate
Yes, that what the manual says. However, it does not work. Furthermore, also on page 92 it says you can have LAN VLANs or IPTV bridge with a WAN tag, but not both. To me that is a non-starter. TP-Link, a competitor device, has WAN tagging and the ability to have LAN VLAN tagging. As a commerical wire router it seems these are desirable features.
- Jan 04, 2019Retired_Member
