Daikan
May 08, 2019Initiate
BR500 connectivity to CenturyLink ISP
It appears that the BR500 (5.6.0.1 or previous versions) is not able to connect the internet when using a CenturyLink ISP fiber modem such as calix 716GE-I. The problem is that CenturyLink requires a...
JohnC_V
May 20, 2019NETGEAR Employee Retired
Hi MrJoshW,
Honest mistake :) I overlooked that on the manual.
JohnCarloV
NETGEAR Community Team
Daikan
May 20, 2019Initiate
Yes, that what the manual says. However, it does not work. Furthermore, also on page 92 it says you can have LAN VLANs or IPTV bridge with a WAN tag, but not both. To me that is a non-starter. TP-Link, a competitor device, has WAN tagging and the ability to have LAN VLAN tagging. As a commerical wire router it seems these are desirable features.
- Jan 04, 2019Retired_Member
