USC-West
Jan 02, 2020Aspirant
BR500 goes back to factory settings after power outage
We had another power outage at home yesterday that out-lasted our UPS and our BR500 reset to the factory settings. Last time we had a similar outage the same thing happened. Is there an internal battery that needs to be relaced, or is there a setting somewhere, or is it just defective? A real PITA each time! Help....! Updated firmware (latest) does the same thing.
- JohnC_VNETGEAR Employee Retired
Hi USC-West,
Welcome to our community! :)
It is possible that the power outage caused the flash to be faulty. Have you tried just removing it to the power outlet with settings on it just to check if it will show the same result?
John
NETGEAR Community Team
