TuKool
Mar 04, 2019Guide
BR500 Insight VPN Client constantly throws Script Error
Insight VPN Client seems to work fine. But constantly getting Script Error.
An error has occured in the script on this page.
Line 5
Char 4948
Error Not Enough Memory
Url InsightVPNClin...
DaneA
Mar 05, 2019NETGEAR Employee Retired
Hi TuKool,
Welcome to the community! :)
Kindly answer the questions below:
a. On what specific device do you see the script error?
b. Do you also see the same script error on other devices that has a VPN client connection to the BR500?
c. How many VPN client devices are connected to the BR500?
d. What is current firmware version of the BR500?
Kindly post an image or screenshot of the actual script error you have encountered.
DaneA
NETGEAR Community Team
TuKool
Mar 05, 2019Guide
Windows 10 machine with Insight VPN Client
Virtual Windows 7 Machine on same computer
I am only currently using those 2 devices.
Only those 2 devices.
V5.5.0.1
Screen Shot attached.
As an additional note, the VPN seems to be working fine. It is just the annoying pop up that occurs every 20 - 30 min or so.
- DaneAMar 06, 2019NETGEAR Employee Retired
Thank you for your feedback. Based from your answers, it seems that the memory that is being described from the script error pertains to the actual memory of your PC. Since your PC is a Windows 10 machine with a virtual Windows 7 in it, it is possible that the PC memory has reached its limit.
DaneA
- TuKoolMar 06, 2019Guide
I don't think so. Here is a Peformance screen from Task Manager. This is with email and a several other apps open including the virtual machine. Memory is at 70%.
Let us try this. On your PC, kindly close all applications such as e-mail, virtual machine and other apps, then open the Insight VPN Client only. Try to open the VPN tunnel and observe if the same script error will appear.
DaneA
