wdreeve
May 31, 2019Aspirant
BR500 Installation Problem
I have a new BR500, and I understand it should find the insight cloud simply by plugging it into internet access. I've done that both on the LAN side of my existing router and directly to the WAN mod...
wdreeve
Jun 03, 2019Aspirant
The BR500 already is registered and working with Insight VPN. The blue and green LEDs are ON. All of the indications on the BR500 user interface show that it is working. But, I cannot get Windows Remote Desktop to work over the VPN. That was my original question: How do I get Windows Remote Desktop to work through the VPN from an off-site PC to a PC connected to the BR500 LAN?
Dan_Z
Jun 04, 2019NETGEAR Expert
Hi wdreeve,
You can download Insight VPN Client (On Windows or MacOS) from NETGEAR download center.
Here is the download link for Windows:
https://www.downloads.netgear.com/files/GDC/BR500/InsightVPNClient-install.exe
Or you can download it from insight vpn user invitation email.
Below is the steps to active insight vpn user:
1.On netgear insight webportal, go to config the BR
2.On Instant VPN Users page,add a VPN user
3.After add the VPN user,VPN user will receive a email
4.On the email,active the vpn user and download vpn client
5.Install insight vpn client on Windows or MacOS,use the vpn user login.
6.After vpn user login,can connect all insight vpn groups.
Thanks.
- Jan 04, 2019Retired_Member
