Ppummill
Feb 03, 2020Apprentice
BR500 no longer connects to Insight after FW5.8.0.1 `
Updated the firmware while the site was dark over the weekend. Insight shows that the Device has failed to connect back. I've rebooted several times. The adorable little "Troubleshoot" button ...
- Feb 04, 2020
3 weeks ago while still on FW 5.7.0.1 I had a BR500 disconnect from Insight. Calles support and did the regular song and dance of factory reset. Delete it out of Insight. Then it came back online with my cute little blue cloud light, Uploaded my config file to it and it promptly disconnected from Insight. Had to do a factory reset again and configure it from scratch. Then it stayed omline with Insight,
warsawtech
Feb 04, 2020Tutor
- PpummillFeb 04, 2020Apprentice
Hi,
thanks for that helpful ...um... insight. And for reminding me of that particular procedure.
Rebuilding the config from scratch after a factory reset seems to have done the trick.
thanks again.
-patrick
