tetrawest
Oct 24, 2020Apprentice
BR500 reset to factory defaults after power outage
I've had the BR500 for more than a year now (and I know because I had to buy a new Insight License!!!, but that is another annoyance). Yesterday, we had two or more quick power outages, where the...
MrJoshW
Dec 14, 2020NETGEAR Employee Retired
Hello,
Checking the NAND cannot be done by a customer, it can only be done with a support agent checking the BR500 through secure diagnostics mode.
And yes, if the device has not been boarded with Insight and was not on a previous firmware that had the existing issue the NAND should not be corrupt.
HabitTH
Dec 16, 2020Guide
MrJoshW wrote:Hello,
Which Version Firmware Number was caused the problem to NAND ?
Thanks.
- MrJoshWDec 16, 2020NETGEAR Employee Retired
Hello,
Issue was fixed in later firmware versions. Versions 5.6 and back would still have the issue if the device is on that firmware.
- tetrawestDec 16, 2020Apprentice
One issue. I was already on the latest Firmware when this happened. I keep the Firmware up to date at all times.
- HabitTHDec 16, 2020Guide
Thanks,
IF you have this version and you didn't register to Insight , This mean the product is fine and no harm will casue to NAND , right?
Also , The NAND Corrupt will influence only on the configuration settings reset during a power down or this will influence about the performance of the BR500 at general and on speed and so on ?
Thanks again .
- HabitTHDec 20, 2020Guide
Thanks,
Thanks again .
- MrJoshWDec 21, 2020NETGEAR Employee Retired
No, the issue should not happen on the latest version as it was patched. However, we can only verify if the NAND is corrupted by enabling the SDM mode on the BR500.
Once you have enabled this, please feel free to send me a private message with the port number and I can verify for you.
- HabitTHDec 24, 2020Guide
How could I enable SDM Mode on BR500 ? Could you explain me please?
There has command that I can run to check the NAND ( I understand on networking and programming )
Thanks.
