tetrawest
Oct 24, 2020Apprentice
BR500 reset to factory defaults after power outage
I've had the BR500 for more than a year now (and I know because I had to buy a new Insight License!!!, but that is another annoyance). Yesterday, we had two or more quick power outages, where the...
tetrawest
Dec 16, 2020Apprentice
One issue. I was already on the latest Firmware when this happened. I keep the Firmware up to date at all times.
HabitTH
Dec 20, 2020Guide
tetrawest wrote:One issue. I was already on the latest Firmware when this happened. I keep the Firmware up to date at all times.
This is still cause to you at last version ?
When this Happen to you first which version you had ?
Thanks
- MrJoshWDec 21, 2020NETGEAR Employee Retired
No, the issue should not happen on the latest version as it was patched. However, we can only verify if the NAND is corrupted by enabling the SDM mode on the BR500.
Once you have enabled this, please feel free to send me a private message with the port number and I can verify for you.
- HabitTHDec 24, 2020Guide
How could I enable SDM Mode on BR500 ? Could you explain me please?
There has command that I can run to check the NAND ( I understand on networking and programming )
Thanks.
