ronaldsnexus
Apr 15, 2021Aspirant
BR500 with can't connect PPoE behind CenturyLink's ISP Actiontec router
Hello All, The BR500 can't be stand alone, becuase it doesn't have a DSL phone input, which means I need to connect to the CenturyLink Actiontec router. I have two BR500's, site (A) and site ...
bbl_1
Apr 15, 2021Tutor
We are not aware of any known issue with PPPoE support.
Recommendation would be to run ActionTec router in router mode, and connect BR500's Internet port to ActionTec's LAN port as a cascaded 2nd router behind it, BR500 will get DHCP IP from the ActionTec router.
ronaldsnexus
Apr 16, 2021Aspirant
Hello,
Thanks for the quickie reply!
Do you have instructions on your site here, how to port forward a cascaded routers?
-illustrations would be super helpful
Thanks!
