KBXR
Apr 16, 2016Aspirant
Cannot print between VLANs
M4100 switch, Port VLANs with routing enabled.
Each VLAN has its own router attached because each VLAN services a different organization with their own External IP. These organizations share a single central printer. Each router has a static route to the other routers on the other VLANs.
-The printer is on VLAN 101.
- I can print from any node on VLAN 101.
- From all VLANs I can ping the printer.
- From other VLANs I can login to the web interface of the printer,
- From other VLANs when I send a print job the printer sees the print job but refuses it with a very generic (i.e. meaningless) error
- If I route the printing to the external IP address of VLAN 101 or replace the M4100 with another (dumb) switch, printing works fine.
WTF??!! What is the printer expecting that is not being properly routed through the M4100 switch? Anyone else had this or similar problems?
- DaneANETGEAR Employee Retired
Hi KBXR,
Kindly try to configure Protected Port(s).
a. On the web-GUI of the M4110-26G, go to Security > Traffic Control > Protected Ports.
b. In the Group ID, select 0.
c. On the Group Name field, you may enter any group name you want.
d. Click the orange bar to display the available ports.e. Select the check box below on the appropriate port where the printer is connected.
f. Click Apply.
g. Check if you will be able to print from other VLANs other than VLAN 101.
As reference guide, read pages 319-320 of the M4100 user manual here. Let me know if it helps.
DaneA
NETGEAR Community Team- KBXRAspirant
No change, unfortunately. Print jobs from vlan 101 work just fine, print jobs from the other vlans fail. The printer logs the print jobs from other vlans as "Cancelled" Not a terribly helpful log entry but it is clear that the print job gets to the printer. The printer logs show the name of the file being printed as well as the name of the user who sent the job, but the job is "Cancelled" almost immediately and never enters the print cue.
I was hopful. :-) Any other thoughts?
Hi KBXR,
Your existing network is kinda intricate. Can you post an image or screenshot of your detailed network setup?
You might want to consider configuring Asymmetric VLANs. However, as per your initial post, each VLAN has its own router. So having Asymmetric VLANs is not advisable.
DaneA
